Hello!
I must admit that I'm fairly new to CAD, so please excuse me if this is a stupid question...:oops:
I wanted to ask if anyone knows how to mute a photograph. I'm working with the aerial photograph as a background, and then placing other objects over top of it. I want the other objects to stand out over what's going on in the photograph, so i've attempted to mute the photograph.
I've tried toying with the resolution, but it's not working.
Any suggestions? Thanks in advance!
You could use wipeout - not that i like using it :x
OR trying sending your image to the back with Draw Order.
:D :D
Not sure if v2000 has these commands but you can try...
imageadjust
this should allow you to adjust some of the image's properties. Mess with the "Fade" settings.
Good luck :)
Sean
depending on the image type you can select the frame and play with "fade" in properties.
Good call :)
Thanks very much, using the "fade" seems to work well.
