mateen Posted December 11, 2010 Posted December 11, 2010 hi, i wanna use ml line with particular distance...... so how can i use....... Quote
ReMark Posted December 11, 2010 Posted December 11, 2010 (edited) You are asking about how to use the MLine command? To my knowledge you cannot assign a radius to a MLine. The distance between lines in MLine can be adjusted using the Scale option. The default is "1". Edited December 11, 2010 by ReMark Quote
mateen Posted December 12, 2010 Author Posted December 12, 2010 ok.... but i want to assign radius in ml line command.... Quote
ReMark Posted December 12, 2010 Posted December 12, 2010 When you figure it out share the secret with us. Quote
nestly Posted December 12, 2010 Posted December 12, 2010 Pick the term that DOES NOT apply to Multilines: [ ] Offset [ ] Justification [ ] Linetype [x] Radius Quote
ReMark Posted December 12, 2010 Posted December 12, 2010 Wish I had know there was going to be a pop quiz. I would have drank less and studied more. Quote
Lee Mac Posted December 12, 2010 Posted December 12, 2010 Use this then spline the resultant LWPolylines? *shrug* Quote
