tem Posted September 22, 2008 Share Posted September 22, 2008 please assistme: is there any kind of tool or script that will allow to appear selected polyline area dimension automatically directly in drawing area. now i should write down it manually in text box Quote Link to comment Share on other sites More sharing options...
lpseifert Posted September 22, 2008 Share Posted September 22, 2008 Field Field name= Object Object type > pick polyline Property= Area Quote Link to comment Share on other sites More sharing options...
tem Posted September 22, 2008 Author Share Posted September 22, 2008 please explain more detailed which field i should edit and tell me the way to do it Quote Link to comment Share on other sites More sharing options...
lpseifert Posted September 22, 2008 Share Posted September 22, 2008 Type Field at the command line [enter] In the Field name section, select Object In the object type area, click on the box w/ the red X on the right Select the polyline you want the area In the Property: window select Area then click OK (notice there are options for formatting) Quote Link to comment Share on other sites More sharing options...
tem Posted September 22, 2008 Author Share Posted September 22, 2008 thank you very much 1 more question: is it possible to not to typing every time "field", instead of it place button or some visual element that refers to this command "field" Quote Link to comment Share on other sites More sharing options...
lpseifert Posted September 22, 2008 Share Posted September 22, 2008 Look at your menu bar Insert > Field... [2 clicks] Quote Link to comment Share on other sites More sharing options...
tem Posted September 22, 2008 Author Share Posted September 22, 2008 ok thanks i meant is this possible to place the same text (area dimension) like linear or aligned dimension methods, with just one click and second question: in that way i do i have to write the sufix each time or is it possible to save this option? Quote Link to comment Share on other sites More sharing options...
skipsophrenic Posted September 22, 2008 Share Posted September 22, 2008 not sure about the first question, but as for the suffix you can put a permanent on in when you create your own dimstyle Quote Link to comment Share on other sites More sharing options...
tem Posted September 22, 2008 Author Share Posted September 22, 2008 it doesnot works, i set suffix in dimension style>primary units, but with field method it doesnot works Quote Link to comment Share on other sites More sharing options...
skipsophrenic Posted September 22, 2008 Share Posted September 22, 2008 right, sorry, that was only thing that i could think of Quote Link to comment Share on other sites More sharing options...
o-o Posted January 29, 2009 Share Posted January 29, 2009 you can mess with the field itself and just paste it into a text box if you like... this way you can maintain complete control of the units i.e. i'm working in mm but want the area in sqM all you need to do is guess the object id value of the individual polyline you wish to measure and bobs your mothers brother %%).Area \f "%lu2%pr0%ps[, sqM]%ct8[1e-006]">% Quote Link to comment Share on other sites More sharing options...
sillyboyy Posted July 7, 2009 Share Posted July 7, 2009 Yes, List command able to let me see the width and height value. but how do i get those value and make the dimension style. or i must write the text myself. Quote Link to comment Share on other sites More sharing options...
wkplan Posted July 7, 2009 Share Posted July 7, 2009 Hello, IMHO it is better, to place the area information inside a block attribute, this will make it much more easy to get access to this information. Anyhow, ther are several tools published here at cadtutor.net: to name a few: http://www.cadtutor.net/forum/showthread.php?t=32396 http://www.cadtutor.net/forum/showthread.php?t=23057 The above deals with "TEXT"-Objects And here's one that can manage block-attribs also: http://www.cadtutor.net/forum/showthread.php?t=31029&highlight=area+field A forum search for "area calculation", "roomtag" etc will sure lead to some lisp who deal with attributes, there are several among them, who places a field value directly to a block attribut. regards Wolfgang Quote Link to comment Share on other sites More sharing options...
sillyboyy Posted July 7, 2009 Share Posted July 7, 2009 thank. i'll try Quote Link to comment Share on other sites More sharing options...
oompa_l Posted August 22, 2009 Share Posted August 22, 2009 i think what you have been talking about relates to what I'm looking for - but those thread numbers didn't seem right. I need a way to have a block attribute refer to an object's attribute such as a pline's area. I know about fields but Im not sure about getting a field to connect with a block attribute. Ultimately I want to be able to produce a room schedule using data extraction techniques...any advice? Quote Link to comment Share on other sites More sharing options...
wkplan Posted August 23, 2009 Share Posted August 23, 2009 i think what you have been talking about relates to what I'm looking for - but those thread numbers didn't seem right. I need a way to have a block attribute refer to an object's attribute such as a pline's area. I know about fields but Im not sure about getting a field to connect with a block attribute. Ultimately I want to be able to produce a room schedule using data extraction techniques...any advice? Hi oompa_I, "any advice?" --> Do a forum search, they have a good search engine here at cadtutor.net Just joking, as I'm now allowed to post links (one of the many advantages for those who post...), I corrected the links, and added a new one, this should suite your needs. For data extraction, take a look at the express-tools, that comes within acad, the attin/attout is a verry powerfull method of reading and rewriting block-attributes. regards Wolfgang Quote Link to comment Share on other sites More sharing options...
azman_28 Posted December 20, 2009 Share Posted December 20, 2009 hi guys. i have tried to use field in creating floor area. after selecting the object, there are no data in the property. Any ideas on how to solve this. Thanks Quote Link to comment Share on other sites More sharing options...
Big G Posted December 22, 2009 Share Posted December 22, 2009 I like that, I did not even know that it was possible to use field command in that way , are there any other tips that you could reccomend using this command, I always use enquiry command, there are always different ways of doing things. Quote Link to comment Share on other sites More sharing options...
