I'm geting the wrong coordinates. I get'em in WCS, i need'em in UCS.
Hi there. Here's my problem.
I draw a couple of circles, and i want to calculate the centroid of them.
I select them using group codes filters.
So far so good. But the coordonates i get for their centers, are in WCS, and i need them in UCS. I found something about the "Utility.TranslateCoordinates" function, but i have problems using it in my case.
Here's the code.
Public Sub CalcImbinare()
  Dim entObj As AcadEntity
  Dim ssetObj As AcadSelectionSet
  Dim grpCode(0) As Integer
  Dim dataVal(0) As Variant
  grpCode(0) = 0
  dataVal(0) = "CIRCLE"
  On Error Resume Next
  Set ssetObj = ThisDrawing.SelectionSets.Add(SetName)
  If Err.Number <> 0 Then
       Set ssetObj = ThisDrawing.SelectionSets.Item(SetName)
  End If
  ssetObj.Clear
  Set ssetObj = ThisDrawing.SelectionSets.Add("SS01")
  ssetObj.SelectOnScreen grpCode, dataVal
  ' SELECTION OF THE CIRCLES IS COMPLETE
  ' NOW I"M TRYING TO USE THE CIRCLE COORDONATES IN MY CALCULATIONS,
  ' BUT I GET THEM IN WCS, AND I NEED THEM IN UCS
  Dim xg, yg As Double
  Dim pct As Variant
  ' I TRIED ALSO " pcs (0 to 2) as Double" TYPICAL FOR A POINT VARIABLE
  ' STILL THE SAME RESULT
  xg = 0 : yg = 0 :
  For i = 0 To ssetObj.Count - 1
       Set pct = ThisDrawing.Utility.TranslateCoordinates(ssetObj.Item(i).Center, acWorld, acOCS, True)
       xg = xg + pct(0)
       yg = yg + pct(1)
  Next i
  xg = xg / ssetObj.Count
  yg = yg / ssetObj.Count
End Sub
The result is that nothing happens, the variable "pct" doesn't get any values.
Thanks in advance!
I created a new UCS at 10,10,10
Drew a circle made it a region and looked at its massprops...
The value i got for centroid was in UCS.. what is your process?
so you say i should lock the circles and then get their center coordinates?
i'll try that too
Well im not sure what you are doing, but if it is just centers of circles you are after, whatever UCS you have current, the coordinate values are displayed in the status bar at the bottom left of your screen....
See if this works any better.
  grpCode(0) = 0
       Set ssetObj = ThisDrawing.SelectionSets.Item("SS01")
       ssetObj.Clear
  End If
  On Error GoTo 0
  Dim pct As Variant
  Dim i As Integer
  Dim entCirc As AcadCircle
  xg = 0: yg = 0:
     Set entCirc = ssetObj.Item(i) 'Explicit casting is not always neccessary, but safe
       pct = ThisDrawing.Utility.TranslateCoordinates(entCirc.Center, acWorld, acUCS, 0)
       xg = xg + pct(0)
       yg = yg + pct(1)
  Next i
End Sub
Wow, it does work. Cool. Nice anwser, slight change but accurate!
:) very nice, thank you very much!
Problem solved!
