I generally use the same settings when generating a 2d section of a 3d object every time i use a new section plane i have to imput the settings again and again. is there a way of setting this up so as when i start a new section plane i dont have to fill out the setttings over and over? Merry Xmas!
I vaguely recall reading something about this recently in an AutoDesk University 2010 handout about going from 3D to 2D by David Cohn. I'll see if I can dig it up.
I'm back. Mr. Cohn had the following tip.
"After you change section settings to produce the desired results for different types of views, you can drag-and-drop a section object on to a tool palette to save those settings as a new palette tool, so you can easily create a new section object using those same settings in the future."
Is this what you were referring to?
