I have text which is justified in various ways (left, right, top, bottom, etc). In order to try and make life a bit more comfortable, instead of having to justify the text anew each time it is inserted, I placed the various forms on a palette, but when I insert the text from the palette it is always justified bottom left. I've checked the properties but can find nowhere where I can set it.
Am I doing it wrong or is it not possible.
when you select the text is there a bit in contents box like "\pxql;"?
because that can cause problems...... solution for this is a lisp called "strip mtext"
but this may not be your problem!
No, its just simple text that was created with dtext
