when i am rendering a 3d object like cylinder its circular edges are not smooth.what is the solution for this?
  1. Type in OP (options)
  2. Goto Display Tab > Display Resolution
  3. Segments in a polyline cure - 10 (optional)
  4. Rendered object smoothness - 10
  5. Contour lines per surface - 10 (optional)
*Alternatively, the command FACETRES also works for this.
