jmerch Posted January 5, 2011 Posted January 5, 2011 what would be an example of trying to find an attribute value that is in a block, then if it's found, execute a routine, otherwise do nothing. I've looked all over and in DXF Groups (which I don't really understand yet)...I thought it'd be a simple ssget like (if (ssget "_x" '((0 . "TEXT")(1 . "BLAH"))) (do this) (do nothing) but don't think that's the way I can go. Quote
Lee Mac Posted January 5, 2011 Posted January 5, 2011 You can't use ssget to select nested entities such as attributes or objects within blocks/xrefs, only primary entities. With that in mind, you will have to iterate through a selection set of all attributed blocks until your attribute is found. Lee Quote
Lee Mac Posted January 5, 2011 Posted January 5, 2011 Consider this code: [color=RED]([/color][color=BLUE]defun[/color] GetBlockWithAttributeValue [color=RED]([/color] value [color=BLUE]/[/color] ss [color=RED])[/color] [color=#990099];; Example by Lee Mac 2011 - www.lee-mac.com[/color] [color=RED]([/color][color=BLUE]if[/color] [color=RED]([/color][color=BLUE]setq[/color] ss [color=RED]([/color][color=BLUE]ssget[/color] [color=#a52a2a]"_X"[/color] [color=DARKRED]'[/color][color=RED](([/color][color=#009900]0[/color] [color=DARKRED].[/color] [color=#a52a2a]"INSERT"[/color][color=RED])[/color] [color=RED]([/color][color=#009900]66[/color] [color=DARKRED].[/color] [color=#009900]1[/color][color=RED]))))[/color] [color=RED]([/color] [color=RED]([/color][color=BLUE]lambda[/color] [color=RED]([/color] i [color=BLUE]/[/color] block _block elist found [color=RED])[/color] [color=RED]([/color][color=BLUE]while[/color] [color=RED]([/color][color=BLUE]and[/color] [color=RED]([/color][color=BLUE]setq[/color] block [color=RED]([/color][color=BLUE]ssname[/color] ss [color=RED]([/color][color=BLUE]setq[/color] i [color=RED]([/color][color=BLUE]1+[/color] i[color=RED])))[/color] _block block[color=RED])[/color] [color=RED]([/color][color=BLUE]not[/color] found[color=RED]))[/color] [color=RED]([/color][color=BLUE]while[/color] [color=RED]([/color][color=BLUE]and[/color] [color=RED]([/color][color=BLUE]not[/color] [color=RED]([/color][color=BLUE]eq[/color] [color=#a52a2a]"SEQEND"[/color] [color=RED]([/color][color=BLUE]cdr[/color] [color=RED]([/color][color=BLUE]assoc[/color] [color=#009900]0[/color] [color=RED]([/color][color=BLUE]setq[/color] elist [color=RED]([/color][color=BLUE]entget[/color] [color=RED]([/color][color=BLUE]setq[/color] _block [color=RED]([/color][color=BLUE]entnext[/color] _block[color=RED]))[/color] [color=RED])[/color] [color=RED])[/color] [color=RED])[/color] [color=RED])[/color] [color=RED])[/color] [color=RED])[/color] [color=RED]([/color][color=BLUE]not[/color] found[color=RED])[/color] [color=RED])[/color] [color=RED]([/color][color=BLUE]if[/color] [color=RED]([/color][color=BLUE]eq[/color] value [color=RED]([/color][color=BLUE]cdr[/color] [color=RED]([/color][color=BLUE]assoc[/color] [color=#009900]1[/color] elist[color=RED])))[/color] [color=RED]([/color][color=BLUE]setq[/color] found block[color=RED])[/color] [color=RED])[/color] [color=RED])[/color] [color=RED])[/color] found [color=RED])[/color] [color=#009900]-1[/color] [color=RED])[/color] [color=RED])[/color] [color=RED])[/color] [color=RED]([/color][color=BLUE]defun[/color] c:test [color=BLUE]nil[/color] [color=RED]([/color][color=BLUE]sssetfirst[/color] [color=BLUE]nil[/color] [color=RED]([/color][color=BLUE]ssadd[/color] [color=RED]([/color]GetBlockWithAttributeValue [color=RED]([/color][color=BLUE]getstring[/color] [color=BLUE]t[/color] [color=#a52a2a]"\nSpecify Attribute Value to Search For: "[/color][color=RED])[/color] [color=RED])[/color] [color=RED])[/color] [color=RED])[/color] [color=RED]([/color][color=BLUE]princ[/color][color=RED])[/color] [color=RED])[/color] [ Currently Case-sensitive ] Quote
jmerch Posted January 5, 2011 Author Posted January 5, 2011 WOW....I think I may have found another way for me to get my result (using scripting from our 3rd party program)...but I will try to push myself to learn what you gave me! Thanks again Lee Quote
