mariass Posted January 6, 2011 Posted January 6, 2011 Hi I have previously only used autocad for 2d drawing, and havent looked into the different workspaces. Now as I decided to test autocad for 3d drawing, I tried to change the workspace to 3d Modelling as I was told. It appears I only have one workspace and its called Architecture. How can I set up a 3d workspace? Im currently using Autocad 2011 Student version and running it on Windows through Virtual Box on a mac. Hope someone can help! Quote
JD Mather Posted January 6, 2011 Posted January 6, 2011 It sounds like you are using AutoCAD Architecture - not vanilla AutoCAD. Close the program. Go to Start>Programs>Autodesk>AutoCAD Architecture>Run as AutoCAD. http://www.cadtutor.net/forum/showthread.php?55678-removing-arch&highlight=vanilla+Autocad Quote
mariass Posted January 6, 2011 Author Posted January 6, 2011 Thank you, but still not working! Do I have to install vanilla seperately? When I type in \ACADM 2011\ it tells me something like "unvalid path." Also, theres no file in the C:\Program Files\Autodesk folder called that (or something with vanilla). In the Autodesk folder I only have the following folders: autocad, 3d studio, design review. Quote
ReMark Posted January 6, 2011 Posted January 6, 2011 You could always try the brute force method. Search your hard drive for a file called acad.exe. Does it exist? Quote
JD Mather Posted January 6, 2011 Posted January 6, 2011 Do I have to install vanilla seperately? No, no, no........ ......no! AutoCAD Archecture runs on top of vanilla AutoCAD - you simply need to start the program with the vanilla profile. When I type in \ACADM 2011\ it tells me something like "unvalid path." Also, theres no file in the C:\Program Files\Autodesk folder called that (or something with vanilla). Of course it gives you an error - I thought those instructions in the referrenced thread clearly inicated that path was for AutoCAD Mechanical - not AutoCAD Architecture and that portion of the path should be edited appropriate for your AutoCAD Architecture install. I don't have AA so I'm not sure exactly what the path is - determining this is usually covered in a Computer Science 101 type class usually taken BEFORE a CAD class. The "vanilla" is a profile setting in your application Options (as shown in the picture) - not a file. Your professor should be able to help you fix this or you might want to hire a fellow student or IT Professional with more experience to help you fix the problem (should take 5-minutes or less). Quote
mariass Posted January 6, 2011 Author Posted January 6, 2011 Ok, I figured it out. Thanks a lot! Quote
