Please help for the next problem:
I'm using Autocad 2005
I have a DWG file with more circles. How can I extract (using lisp) the accurate 3D coordinates of theirs centers (XYZ).
For example: (see attached dwg-file) the marked circle has center (60,40,5)
But using lisp (entget)…
((-1 . ) (0 . "CIRCLE") (330 . )
(5 . "2E77B") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "2") (48 .
0.25) (100 . "AcDbCircle") (10 40.0 5.0 60.0) (40 . 5.0) (210 1.0 0.0
2.22045e-016))
So, the coordinates of the center are X40; Y5; Z60?
How can I get the correct values?
Thank you for any help.
circles.dwg
If you want the center point in WorldCoordinateSystem ( WCS ), then use the (trans) function
If the entity ename is en, then:
(trans (cdr (assoc 10 (entget en))) en 0)
or
(trans (cdr (assoc 10 (entget en))) (cdr (assoc 210 (entget en))) 0)
-David
Uhm yes, David's code should work. Though your DWG's circle lists as:
            center point, X=  60.0000  Y=  40.0000  Z=  [b]10.0000[/b]
           radius    5.0000
And using David's 1st code sample:
Command: (trans (cdr (assoc 10 (entget (setq en (car (entsel)))))) en 0)
Select object: (60.0 40.0 10.0)
Thanks everyone. It worked.
The mistake was mine, my question was a little childish, I have not applied correctly in my attempts "trans"
