leaf spring animation on inventor need some help
hi there
i am putting together an engine on autodesk inventor 2010, and want to anamate the engine i have managed to make the piston assembly move.
my problem is i have a cam which moves a leaf spring and i am not sure show to make the spring bend where it should as inventor does not know it is a spring.
any help would be great i have attached a word doc with some pictures.
thanks
Chizz
Have you examined the adaptive leaf spring in the Scissors example?
ah ok thanks for your help i will look into that and see if i get anywhere.
many thanks
