Hello friends
someone help me to fix this Auto cad 2007 Error.
fatal error unhandled access violation writing 0x4deba990 exception at 49ad28h
Thanks
Have you tried researching the error at the AutoDesk website?
What were you attempting to do when the error occurred?
I just Reinstalled Auto cad.then working is fine.
I would have suggested using the Repair option before doing a reinstall. You may have fixed the problem for now but I would expect it to return.
Did you also download and install all service packs and any applicable hot fixes?
OK thanks...but here is i am using Crack Version.i cannot installed services pack and hot fixes.
is there free services pack and hot fixes available on NET?
OH !!!! :shock: You do realise that what you are doing is highly illegal. You shouldn't expect any help from here.
You're using an illegal version of AutoCAD and you expect us to help you?
No, there are no free service packs and hot fixes. Like I said, I believe the problem will, over time, resurface and you'll be faced with reinstalling an illegal copy of AutoCAD, again. Do you like going around in circles?
