I found a lisp to do the following:
finds all *. dwg from a file and import them into one DWG. All is well so far but he did not insert them well. What I need is if someone can help me to modify the sequence when such blocks are inserted to make the following:
-insert "name of block" units "m" insertion point "0,0,0" XScale "1 " Yscale "a" rotation scale "0.00 g"
following is lisp that I found:
tst1.LSP
Thanks in advance!
Whats wrong when there inserted ? more info please.
Also if the dwgs are not drawn using the same co-ordinate base point then insert about 0,0 will not work.
I would also ask for more info? what is your final goal, perhaps this lisp routine is not the best way to obtain that final objective.
