Jscott85 Posted January 18, 2011 Posted January 18, 2011 I am having trouble exporting from Revit to Sketchup, I want the model to go into Kerkythea eventually. I did the following steps: Export>CAD Formats (from Revit) ----->Options ---------->Solids (3D views only) ---------->Export as polymesh>OK Save As Type> AutoCAD 2004 DWG Files>don't change anything else... should be "Automatic, Long" and "Current View" ----->Give File a Name>SAVE Then: n new SU file: Import>.dwg file type --------->find your exported dwg from Revit step above >Options ----->Merge Coplanar Faces=Check ----->Orient Faces Consistently=NO ----->Units=Feet ----->Preserve Drawing Origin=Check The problem is I cannot find the exported DWG. file in the SU import dialog box. Any suggestions? Thank you -Justin Quote
troggarf Posted January 21, 2011 Posted January 21, 2011 Try exporting from cad as a .DXF format and opening it in SkecthUP Quote
