Well Remade all page setups in a new template. The new page setup worked great for my print to pdf, got rid of the moving lines issue that I had. Lines would be missing on one page the would show up on the other. Now thats fixed. Thanks. As for printing my 11x17 layout tabs to letter it has not worked as of yet. I am planning on trying again when I have.
Thanks for all your help StykFacE.
Matt
What procedure are you using that's not working? Can you give me an example of your settings?
  • Replies 24
  • tzframpton
    10
  • Honda Matt
    9
  • joker3201
    4
  • Civil3DReminders
    1
Heres step by step:
1. Select all layout tabs that I want to print.
2. Right click, Select "Publish Selected Layouts...
3. Select all sheets. Under Page Setup / 3D DWF switch to my LETTER page setup.
4. Under Publish to... switch to Plotter named in page setup.
5. Double check that everything is checked correctly and hit publish.
One sheet print out with the error that I showed before.
I use the same procedure when I print to pdf. Just select my PDF page setup and that works just fine.
Here is my page setup to print to letter & the Publish dialog box.
It works fine if I plot one layout tab at a time.
LETTER Setup.pdf
Publish Dialog Box.pdf
Edited by Honda Matt
I left it go for awhile and nothing happened.
Thanks
Are you from Pennsylvania? Just curious because I have noticed folks from that part of the world using 'left' in that way.
Heres step by step:
[ATTACH]25932[/ATTACH]
[ATTACH]25933[/ATTACH]
Hmm. Have you tried testing it on another printer? To me it seems the error might be the printer since the publish to Letter works when you are creating PDF's.
Wish I could try another printer. We only have the one. Never thought it could be the copier/printer that we have.
I'll just keep doing things the way I am and hopfully we get a better copier/print soon and hopfully that will fix the problem.
Thanks
Matt
