osnap's turing off randomly
I'm using acad 09 and ill turn my osnaps on and be using them, then randomly they not so much turn off completly but if i have all osnaps selected it will randomly change to only the endpoints, quite irritating when you need something else and have to keep going back and changing things becuase it turns them off... any suggestions on why this is happening?
Sounds like a lisp or script you are using is doing it.
I think its a certain command/commands that do that. Do you know which command you use that you notice it happening after?
I am using 07 and I too have the same problem. The crazy thing is that it can be as soon as I open a drawing and I know that they were all on in the one I was just using. Could happen switching from drawing to drawing that are open already too.
it could be a lisp, but all my lisps are copied from another person and they dont have the same problem.
Osnap settings are saved in the .dwg file, Switching between drawings won't affect the settings
Probably from escaping out of a lisp that doesn't have error control.
