Is there any method to compress the autocad file, without using PURGE & AUDIT command.
If you are looking to reduce the size of the file, other than zipping it, I don't think there are any other ways available than the two you have already mentioned. Why?
you can WBLOCK * the drawing to perform a PURGE without using the command. As Mark said, why?
