Buggsy Posted January 26, 2011 Posted January 26, 2011 Hi ya all, With all the info that is on this site, I can't seem to find the answer to my problem. I've been working with this drawing that has 10 PS tabs. The wipeout command & textmask command works in most of the PS ports, but some of the PS ports the background shows through the mask/wipeout. The drawing is in MS and all the Title/Borders/Dims/Text is in PS. Can someone lend me some help to get my wipeouts & textmasking to work in all PS ports? Quote
SLW210 Posted January 26, 2011 Posted January 26, 2011 Do you have the wipeouts on layers that are frozen in the viewport? Quote
Buggsy Posted January 26, 2011 Author Posted January 26, 2011 There are no frozen/locked/turned off layers in any of the PS ports or MS. Viewports were created or put on the Defpoints layer so they don't print the PS outline. When using textmask, textmask defaults to putting mask on current layer, so all mask go to text or dim layer. Quote
SLW210 Posted January 26, 2011 Posted January 26, 2011 Why do you have your viewports on Defpoints layer? I recommend creating a layer (Viewports is a good name) and setting it NoPlot. Quote
Buggsy Posted January 26, 2011 Author Posted January 26, 2011 Creating an extra layer is not needed when Defpoints does what I need it to do. Hide the viewport outline. Can you explain why you have narrowed your thought on my layer usage when textmask defaults to current layer that I'm on (such as text layer)? Quote
SLW210 Posted January 26, 2011 Posted January 26, 2011 Using Defpoints layer for anything is bad form and not recommended. Do a search on CADTutor or anyother related site and you will see some of the problems associated. Check out this thread for starters http://www.cadtutor.net/forum/showthread.php?54869 Not saying that is your problem. I will look into it some more later if you like. Try doing some searching in the mean time. Quote
CyberAngel Posted January 26, 2011 Posted January 26, 2011 When I see this behavior, I think first of draw order. Try bringing the text to the front. Quote
Buggsy Posted January 26, 2011 Author Posted January 26, 2011 Ok, I believe ya all and will Standardize this in the future. I have changed all viewports to a viewport layer and still the textmask / wipeouts do not mask in some of my viewports, while most of my viewports, the textmask / wipeouts do work. Quote
Buggsy Posted January 26, 2011 Author Posted January 26, 2011 Already tried this (DO) with no results. I've even unmasked everything, purgedall, saved, closed, and reopened to do texrmask and still doesn't work in just 2 of the 10 view ports. Quote
SLW210 Posted January 26, 2011 Posted January 26, 2011 Are all of the viewports in 1 layout tab? Try to compare the properties of a working viewport and a non-working viewport. Are the wipeouts in Model or Paper? Quote
Buggsy Posted January 26, 2011 Author Posted January 26, 2011 There are 10 PS tabs. Most have single Viewports but a couple tabs have multiple viewports. Quote
SLW210 Posted January 26, 2011 Posted January 26, 2011 Maybe I will have more time tomorrow, I am having difficulty recreating your problem. Quote
Glen1980 Posted February 2, 2011 Posted February 2, 2011 1. Silly question, but the text masks that aren't working are they in all of the viewports? If it only appears in one viewport maybe the mtext box has been dragged smaller than the text, I get this sometimes when people have formatted their own paragraphs you can't tell the box has changed size. When I get this problem the MText box has no physical size and as the background mask is dependent on the mtext box not the text inside there is no background. I have to open the mtext command and drag the rulers about to get the bg mask to appear. 2. Are your wipeouts quadrangles? I have found our printer won't do polygon wipeouts even though they appear fine in the viewports. Quote
Dastardley Posted August 18, 2011 Posted August 18, 2011 I have the same problem. We use 2010 & 2011 and this only happens on some drawings in the set. The Viewport is on VP Layer (ON & THAWED) Draw order hasn't helped Creating new MText in the drawing also hasn't helped but if i choose the colour fill it works. Quote
SLW210 Posted August 18, 2011 Posted August 18, 2011 Could you post the file and/or some screen shots? Quote
Buggsy Posted August 18, 2011 Author Posted August 18, 2011 Could you explain futher on this colour fill? How do you choose colour fill? Quote
choopyguz Posted August 22, 2011 Posted August 22, 2011 Hi all new here, I have found with wipeouts that some printers do not like them, especially from PDF's that are scaled down, the way I get around this is to do a pline around the object and put a solid hatch with a colour of 255 (white) behind the object, and the same with background mask use colur 255. Quote
