Zooooom - But faster
How do I change the speed of the "zoom in" and "zoom out" commands in autoCAD 2008.
I would like it to be faster.
straight from help file
ZOOMFACTOR
tab-left.gifConcepttab-right.giftab-left.gifProceduretab-right.giftab-left-x.gifQuick Referencetab-right-x.gif
Type:IntegerSaved in:RegistryInitial value:60
Controls how much the magnification changes when the mouse wheel moves forward or backward. Accepts an integer between 3 and 100 as a valid value. The higher the number, the more the change
Hello guys,
That only changes the zoom speed on the mouse wheel. I am looking to change the speeds whin I click on the zoom in and out Icons.
Sorry if I may have been slightly blunt with the question.
Try setting Vtduration to a lower number, or turn view transition off with Vtenable=0
don't use anything else other than the wheel to zoom.
Do you mean your VIEW TRANSITIONS? if so type VTOPTIONS and increase the speed.
I have mine switched OFF!
Magic. That works a treat.
Thanks everybody.
