question about blocks
I had a block definition that i've inserted into my drawing multiple times. After that, I added an editable attribute to the block definition, but when I did so, the blocks that were inserted previously did not update with the editable attribute attached.... It appears that the editable attribute will only be assigned to blocks which are inserted after the attribute is assigned... is this true?
