MacCad Posted February 2, 2011 Share Posted February 2, 2011 Hi, I need som help. Say i've drawin a cube like this (bad drawing I know) _____ / /l /_____/ l l l l l l / l_____l/ Now I want it to plot of as above, however when I go to plot it off I can see all the lines behind the 3 faces you can see up there (it looks like a wireframe of the cube instead of a solid) What can I do? Thanks. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted February 2, 2011 Share Posted February 2, 2011 use the HIDE command. Quote Link to comment Share on other sites More sharing options...
hoss Posted February 4, 2011 Share Posted February 4, 2011 Depends on how you have drawn the cube It its a solid object, then as StykFacE said, hide or right click on viewport and select shade plot and tick "hidden" if you have drawn it in wireframe you have to trim the lines Quote Link to comment Share on other sites More sharing options...
Sittingbull Posted February 4, 2011 Share Posted February 4, 2011 Try the shaded viewport options in plot settings. Quote Link to comment Share on other sites More sharing options...
MacCad Posted February 11, 2011 Author Share Posted February 11, 2011 The hide command worked. Thanks for all the replys and help. Quote Link to comment Share on other sites More sharing options...
