crash66 Posted February 4, 2011 Posted February 4, 2011 Could someone please provide some advice on how to successfully convert from a 3D *.dwg to a solidworks file? I have tried several different export/import options and nothing seems to work. When I export the file, then open in solidworks file, certain features are missing or incomplete. What steps do I need to perform in Autocad to facilitate the export? Thanks! Quote
kencaz Posted February 4, 2011 Posted February 4, 2011 You should be able to export your AutoCAD solids to .SAT and then import into SW. I do this in Inventor all the time. You object is not Parametric however... KC Quote
crash66 Posted February 4, 2011 Author Posted February 4, 2011 That works well, now that I have exploded all of the blocks and then exploded the sub-blocks. The original issue was that the blocks were not importing correctly. Thanks for the help. Quote
