MikeMc52
Getting information from Non Uniform Blocks
MikeMc52
In the help files it states that objects in non-uniform scaled blocks will not be extracted. If I add an attribute to the block that would contain the information I needed would it be extracted?
When I draw a 3D pipe, I have three blocks I use:
Left thread end
Pipe
Right thread end
When I have a 3D pipe to draw, I insert the left thread end (uniform scale), then I insert the pipe block and scale the “Y” to the length I need (minus 2”- one inch for each end) and then I insert the right thread end.
What I would like to do is add an attribute to the “Pipe” block that would include the length and have that attribute exported so I could use it for the length of pipe to be used to order and construct the pipe. Will this work?
Share this post
Link to post
MikeMc52
And the answer is: Even though it probably will not give you a lot of information for an non uniform scaled block it will read the attributes and output them
And I am happy. :D
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
