way to know all objects in the drawing?
Hi
im using DesignCenter, there are blocks i cant see in the file. is there a way to get a info list about all objects in the drawing?
Thanks
Shay
You can issue "DBLIST" command to see all tangible objects, and "PURGE" command to see all named objects (i.e. Blocks, Layers, Linetypes, ...)
Mehrdad Ahankhah
www.ACAD.ws
www.IranCAD.com
sorry. i forgot to mention that im using LT. :(
I think the only difference between full edition AutoCAD and LT is the restriction of LT in programming and customizing and not in commands, so commands like: "DBLIST", "PURGE", "STATUS", etc. are valid in LT.
