lubracali
[VBA/Autocad]The shortest distance between two lines
lubracali
I'm trying to figure out how to find the nearest point of a line to another line, but I can not find the right approach.
The lines do not intersect, but at a point are very close.
I should write something to tell me the coordinates of this point.
The two lines are drawn in 3D and are skew.
I need some ideas on how to tackle the problem.
Share this post
Link to post
Tharwat
Hope this help you out with what you looking forward .
(vl-load-com)
(setq ss (vlax-ename->vla-object (setq e (car (entsel "\n Select First Line :")))))
(setq ss1 (vlax-ename->vla-object (setq e1 (car (entsel "\n Select Second Line :")))))
(setq pt (vlax-curve-getClosestPointTo ss (cdr (assoc 10 (entget e1)))))
Tharwat
Share this post
Link to post
lubracali
I think I had two windows open on the forum I posted by mistake on both, this is the right place, my request is for vba and not for lisp.
I apologize now in the other post.
We can continue here.
Share this post
Link to post
lubracali
I apologize for posting in wrong section.
My question is about VBA and do not lisp.
I thank those who answered me, I will try also to learn lisp.
Maybe a moderator can close?
I apologize again.
Share this post
Link to post
SLW210
I merged the threads. The responses involving LISP my help others so I will leave that.
Share this post
Link to post
BIGAL
Maybe a help drew an arc that crosses a pline and work out its intersection point
ThisDrawing.Utility.GetEntity oPoly, snapPt, vbCr & "Select polyline :"
Set arcobj = ThisDrawing.ModelSpace.AddArc(vertPt, cRad, endang, startang)
retval2 = arcobj.IntersectWith(oPoly, acExtendOtherEntity)
there is 4 different intersectwith options check help
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
