skfarkowsky Posted February 10, 2011 Posted February 10, 2011 Hi All I have a problem that drives me mad and have no clue how to fix it. Basically when i set up the layout to an A1 size and want to insert a drawing frame, the frame (as a block) is much bigger than it should be. Many thanks Piotr Quote
ReMark Posted February 10, 2011 Posted February 10, 2011 Are you referring to a title block and border when you say "drawing frame"? Quote
skfarkowsky Posted February 10, 2011 Author Posted February 10, 2011 yes a title block and border Cheers Quote
ReMark Posted February 10, 2011 Posted February 10, 2011 I have encountered that same problem on ocassion. I've been forced to use the Stretch command to make it fit. I'm not sure what the cause is other than to say AutoCAD's concept of what constitutes a "printable" area given the plotter and sheet size I am using differs from mine. Quote
SLW210 Posted February 10, 2011 Posted February 10, 2011 Are you inserting the correct size title block for the print size? What are your insert units? When you say it is much bigger, is it 25.4 times bigger? Quote
