jcap91163 Posted February 12, 2011 Share Posted February 12, 2011 I was wondering if there is a method you geniuses around here have to make the wipeout command work with curved elements, i.e., a toilet block which of course has a great number of curves and arcs, and my goal is to be able to make a wipeout and send it back so when inserted the floor hatch is behind the block, as always suggestions are welcomed and in advance many, many thanks for your time and patience. Quote Link to comment Share on other sites More sharing options...
edwinprakoso Posted February 14, 2011 Share Posted February 14, 2011 As far as I know, there is no way to do that with wipeout. You may want to try using solid hatch to do that. Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 14, 2011 Share Posted February 14, 2011 http://www.theswamp.org/index.php?topic=28059.0 Quote Link to comment Share on other sites More sharing options...
jcap91163 Posted May 31, 2011 Author Share Posted May 31, 2011 just find out the solution, many thanks for your time Quote Link to comment Share on other sites More sharing options...
irneb Posted May 31, 2011 Share Posted May 31, 2011 You could of course also use the ExpressTools' SuperHatch command: Allows for the "error-tolerance" in simulating the curvature. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 31, 2011 Share Posted May 31, 2011 just find out the solution, many thanks for your time You found a solution to a problem, but do not want to share it? Quote Link to comment Share on other sites More sharing options...
