can't delete it my self ^^
Edited by Asger
Been watching & reading tutorials the last two days, and have been making good progress considering i had zero CAD experience but i think i've messed something up becuase every time i start a new part (standard.ipt) the view is top side, and i have to manually change the current pane to front on the view cube, shouldnt it be front as default?
2'nd issue is when trying to use the Hole tool, and i've marked center's in the sketch and return to use the hole-tool, i can't see or execute holes on the marks, how do i make them visible? i can't slice it with F7 for some reason
You posted in the beginners AutoCAD forum, repost in Inventor forum.
