Hello,
I'm new in this forum and new to visual lisp programming.
So i need help with my code.
(defun c:imp (/ file_to_process file_open sx_f text_list str_find s_x s_y icount1 icount2 icount cross_ent iname)
 (setq file_to_process (getfiled "\nChoose file" "F:\\" "txt" 16))
 (setq str_list (ssadd))
 (setq text_list (ssadd))
 (setq iName 0)
 (vl-cmdf "._zoom" "_E")
 (if (setq file_open (open file_to_process "r"))
    (while (setq sx (read-line file_open))
      (if (setq str_find (ssget "_X" (list (cons 0 "*TEXT")(cons 1 sx))))
      (setq text_list (ssadd (ssname str_find 0) text_list))
      (setq str_list (ssadd (ssname str_find 0) str_list))
      (setq iName (1+ iName))
      (setq s_X (cadr (assoc 10 (entget (ssname str_find 0)))))
      (setq s_Y (caddr (assoc 10 (entget (ssname str_find 0)))))
       (setq iCount1 s_X)
      (setq iCount2 s_Y)
      (setq iCount "")
          (while iCount
        (setq iCount1 (1- iCount1))
        (setq iCount2 (1- iCount2))
            (if (setq cross_ent (ssget "_C" (list s_X s_Y 0) (list iCount1 iCount2 0) '((62 . 20))))
        (setq iCount nil)
              (setq str_list (ssadd (ssname cross_ent 0) str_list))
          );progn
        );if
          );while
        );progn
      );if
    );while
 ) ;if
 (sssetfirst nil str_list)
 (close file_open)
I want to find first polyline that is surrounding the text object, but when i run my code it finds it but doesn't select it.
I think the problem is here:
            (if (setq cross_ent (ssget "_C" (list s_X s_Y 0) (list iCount1 iCount2 0) '((62 . 20))))  ;a polyline with color = 20
        (setq iCount nil)
          );progn
        );if
But i can't get it work right.
Can someone explain what i'm doing wrong ?
1. Why Z in cutting frame coordinates (list s_X s_Y 0) (list iCount1 iCount2 0)? It is no need because will be ignored. And why it is Integer 0 not Real 0.0?
2. The best way to view your cutting frame temporarily add to your code
(vl-cmdf "_.rectangle" (list s_X s_Y) (list iCount1 iCount2))
and set break point after it.
