Cadax Posted February 15, 2011 Posted February 15, 2011 Hello all, We're in the process of beginning our first Revit MEP project and would like to have all users to store their local copies of the central project model in a folder structure like...C:\BIM_Projects\ Is there a way to change the default save location when creating a local file from the central file? The default location seems to be the 'Documents' folder and there doesn't appear to be an option to change target location. Any help much is appreciated. Thanks. Quote
G-Prime Posted March 31, 2011 Posted March 31, 2011 Click the Revit button in the top left, and go to options on the bottom right should be labelled "Options" and go to the tab called file locations, change the Default path for users files: to the path you want. Quote
Cadax Posted April 5, 2011 Author Posted April 5, 2011 Thank you G-Prime. I had figured it out shortly after I posted the question but forgot to reply that I had. Quote
