Ok guys have a tough one for you that has been driving me nuts.
My current situation is that I need to have the following list in a particular order x2
The first order needs to be set in the (nth x (nth 0)) portion of the list. This portion of the list needs to be in alphabetical order much like it currently is in this list. (Just happen to come out that way)
The second ordering will happen in the (nth 1 (nth x (nth 1))) portion of the list and it needs to be in numerical order within the list of a list of a list.
Was trying all sorts of stuff and couldn’t figure it out everything from VL-sort to VL-remove the min and send back the appended value and try it again (was getting messy really quick)
After it is all order it will need to be saved back to it-self.
Current structure
(LIST(LIST)(LIST(LIST)))
Current Setup
'((("W1" 18.0 10.5 "X")
                          (("W2" 282.0)
                          ("W3" 2.0)
                          ("W6" 205.5)
                          ("W7" 78.5)))
(("W2" 300.0 12.5 "Y")
                          (("W1" 2.0)
                          ("W8" 120.0)))
(("W3" 20.0 12.5 "Y")
                          (("W1" 2.0)
                          ("W8" 120.0)))
(("W4" 98.0 68.0 "X")
                          (("W5" 62.0)
                          ("W6" 125.5)
                          ("W7" 1.5)))
(("W5" 160.0 69.5 "Y")
                          (("W4" 1.5)
                          ("W8" 63.0)))
(("W6" 223.5 12.5 "Y")
                          (("W1" 2.0)
                          ("W4" 55.5)
                          ("P2" 37.5)))
(("W7" 96.5 12.5 "Y")
                          (("W1" 2.0)
                          ("W4" 55.5)
                          ("P1" 37.5)))
(("W8" 18.0 132.5 "X")
                          (("W2" 282.0)
                          ("W3" 2.0)
                          ("W5" 142.0)))
(("P1" 68.0 50.0 "X")
                          (("W7" 28.5)))
(("P2" 225.0 50.0 "X")
                          (("W6" 1.5))))
Any help you guys can provide on this or point me in the right direction would be of great help.
Thank you in advance.
CadWarrior
(defun _sortAlph (lst)
 (vl-sort
   (mapcar
     (function
       (lambda (x) (cons (car x) (vl-sort (cdr x) (function (lambda (a b) (< (car a) (car b)))))))
     lst
   (function (lambda (a b) (< (caar a) (caar b))))
(defun _sortNum (lst)
 (vl-sort
   (mapcar
     (function
       (lambda (x)
         (cons
           (car x)
           (vl-sort
             (cdr x)
             (function (lambda (a b) (< (distof (substr (car a) 2)) (distof (substr (car b) 2)))))
     lst
   (function (lambda (a b) (< (distof (substr (caar a) 2)) (distof (substr (caar b) 2)))))
Probably no need for distof...
 (vl-sort
   (mapcar
     (function
       (lambda (x)
         (cons (car x)
               (vl-sort (cdr x)
                        (function (lambda (a b) (< (distof (substr (car a) 2)) (substr (car b) 2))))
     lst
   (function (lambda (a b) (< (substr (caar a) 2) (substr (caar b) 2))))
Thank you for the help Alanjt
Ok _sortalph works great but i think you misunderstood _sortnum which is my fault.
Please for Below for more clerity.
Orginal lists
                          (("W2" 282.0)
                          ("W3" 2.0)
                          ("W6" 205.5)
                          ("W7" 78.5)))
New List
                          (("W3" 2.0)
                          ("W7" 78.5)
                          ("W6" 205.5)
                          ("W2" 282.0)))
Hope this clears it up a bit.
This?
(defun _Sort ( lst )
 (mapcar
   (function
     (lambda ( item )
       (list (car item)
         (vl-sort (cadr item)
           (function
             (lambda ( a b ) (< (cadr a) (cadr b)))
   lst
 (vl-sort
   (mapcar
     (function
       (lambda (x)
         (cons (car x)
               (vl-sort (cdr x)
                        (function (lambda (a b) (< (cadr a) (cadr b))))
     lst
Can't test.
Thank you!!! Thank you!!! Thank you!!! Thank you!!! Thank you!!!
Thank you Alanjt for the Correct Alphabetical sorting.
and Thank you Lee Mac for the correct Numerical sorting.
Now if you guys could explain it to me I would be most appreciative because at this moment i cant begin to fathom how to work this. This sorting style just blows my mind away I'm use to table based programs like MySQL
