Autocad Classic 2011, how do I get a smooth edge?
  • Replies 20
  • Tiger
    4
  • eldon
    3
  • Jack_O'neill
    3
  • trn714
    3
Posted Images
I think you are missing some info or possibly some images?
im a newbie at this, can someone give step by step?
Step-by-step for doing what?
Did you try to print your drawing? Iff the edge your takling about is smooth, then you have no trouble.
Try the regen command like JD suggested.
Iff it's not that, give us some more info, the pictures you posted are not visible(at least not to me).
SB
edit:
Okay, got the pictures.
U need to use the fillet command.
Read this topic:
http://docs.autodesk.com/ACD/2011/ENU/filesAUG/WS1a9193826455f5ffa23ce210c4a30acaf-69ce.htm
Edited by Sittingbull
Got it
As I understand it, new members can't post pictures or upload files till thier post count reaches 10. Moderators, correct me if I'm wrong about this, please. Perhaps it's time to reconsider that policy, as it really makes answering questions like this easier if the person asking can put up a pic.
This whole thread mystifies me.
Jack - sub-10 post-count'ees can post both link and pictures, but nothing appears here for me....
Am i the only one who could see the pictures? I right clicked on the symbols, and opened the images in a new tab, and this is what I saw. Hence my reply about using the Fillet command.
Did the same :wink:
Thanks Tiger!
I hadn't looked at the forum rules for a while, here's a clip in case anyone else is confused about that:
Links in posts
In addition to the above, if you add a link in your posts, they may be moderated. This means they will not appear until a moderator has checked them. If you want your post to appear immediately, do not include links.
Junior Members
Once your post count has risen to 10 and your title changes to "Junior Member", all the restrictions will be lifted and you can use the forum in the normal way. The change of status happens automatically and you don't need to do anything.
Obviously, we'd rather not have to apply such restrictions to newly registered users but it is a very effective way of preventing most spam.
Thanks for joining the forums - I hope you find the experience rewarding.
CADTutor
This is how the original post first appeared, and still does now. The little symbols are not clickable for me.
Ain't seeing no pictures here - but it's a cut and dry Fillet-question from Eldons pictures :thumbsup:
Might it be a browser feature? This is what I see in Google Chrome
Yeah, apparently it is, in IE I can see the squares with red Xes.
Meh, at least he got it sorted :)
