GAAMS Posted February 22, 2011 Share Posted February 22, 2011 Does anyone know if AutoCAD 08 has the ability to create wireframe arrows without building them from scratch? I'm trying to show circulation patterns on a landscape plan. I'd like to be able to click and drag like a polyline etc. Thanks! Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 22, 2011 Share Posted February 22, 2011 What about using a Dynamic Block? Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted February 22, 2011 Share Posted February 22, 2011 You can't use leaders? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted February 22, 2011 Share Posted February 22, 2011 Or you can use the MEASURE or DIVIDE command to distribute blocks along a polyline. Quote Link to comment Share on other sites More sharing options...
GAAMS Posted February 22, 2011 Author Share Posted February 22, 2011 Leaders don't give the free form graphics I'm looking for. I'd like to be able to curve them like a spline. Am I missing something on their capabilities? Quote Link to comment Share on other sites More sharing options...
GAAMS Posted February 22, 2011 Author Share Posted February 22, 2011 Give me a minute to check that out. Not too familiar with the dynamic block. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted February 22, 2011 Share Posted February 22, 2011 Okay here's the next question, are you wanting arrows to be evenly distributed along a path? Or are you wanting a Leader with a single arrow head that has an arced tail? There's two different options and can be accomplished easily. Quote Link to comment Share on other sites More sharing options...
GAAMS Posted February 22, 2011 Author Share Posted February 22, 2011 Leader with a single arrowhead. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted February 22, 2011 Share Posted February 22, 2011 That's what I was thinking. Check out this LISP routine. The scale is based on the DIMSCALE variable. Set that and you're all good. arc_dim.lsp Quote Link to comment Share on other sites More sharing options...
GAAMS Posted February 22, 2011 Author Share Posted February 22, 2011 Okay. Thanks everyone. I've got enough to explore and work with the options. gtg. Project due at 5:00! Quote Link to comment Share on other sites More sharing options...
RobDraw Posted February 23, 2011 Share Posted February 23, 2011 There are options within the leader command to get what you describe. After starting the leader command, type "S" for settings. You can use the spline option and increase the maximum number of segments or check the box for no limit. Quote Link to comment Share on other sites More sharing options...
GAAMS Posted February 23, 2011 Author Share Posted February 23, 2011 Ok. I'll try that option. Thanks. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 23, 2011 Share Posted February 23, 2011 Try a custom linetype. Quote Link to comment Share on other sites More sharing options...
