SPACECADET Posted February 22, 2011 Posted February 22, 2011 I need to Attout the title block info from multiple layouts into an excel sheet that I can then edit and back populate (ATTIN) my drawing borders. Dataextraction doesn't bring the all important block handle that I need for the attout/in process and It seems I will have to manually attout to txt and import to excel for each layout...150 in total. Can this be automated. or is there a routine that can output to txt the handle for a given block along with it's layout tab number so i can paste it into excel in the correct order. Confused. Any help welcomed. Quote
ubsure Posted March 1, 2011 Posted March 1, 2011 Maybe you can make a lisp getting the atributes, and then writing them to excel like this: (defun c:csv ( / wrkfile ofile name adress phone) (setq wrkfile "C:\\Test.csv") (setq ofile (open wrkfile "a")) (setq name "ubsure") (setq adress "street 22") (setq phone 12345678) (write-line (strcat name ";" adress ";" (rtos phone 2 0)) ofile) (close ofile) ) from there you can use them for your attin. ubsure Quote
