autolisp Posted February 24, 2011 Posted February 24, 2011 Dear all Plz advice which is best method of create layer inside the lisp 1st (setq oldlayer (getvar "CLAYER")) (if (tblsearch "LAYER" "Dr") (setvar "CLAYER" "Dr") (command ".LAYER" "M" "Dr" "C" "6" "" "") ) (setvar "CLAYER" oldlayer) 2nd (if (not (tblsearch "layer" "dr")) (progn(command ".LAYER" "M" "dr" "C" "50" "" ""))) Quote
Tharwat Posted February 24, 2011 Posted February 24, 2011 I guess this is one of the best .. (if (not (tblsearch "LAYER" "Dr")) (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 "Dr") (cons 70 0) (cons 62 6) )) ) Tharwat Quote
autolisp Posted February 24, 2011 Author Posted February 24, 2011 I guess this is one of the best .. (if (not (tblsearch "LAYER" "Dr")) (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 "Dr") (cons 70 0) (cons 62 6) )) ) Tharwat dear sir thx for suggestion Quote
Tharwat Posted February 24, 2011 Posted February 24, 2011 dear sirthx for suggestion You're welcome anytime . Tharwat Quote
David Bethel Posted February 24, 2011 Posted February 24, 2011 If you really want in insure setting to a layer: ;++++++++++++ Make Layer Current +++++++++++++++++++++++++++++++++ (defun SetLayer (name / ldef flag) (cond ((or (not name) (not (snvalid name))) (princ "\nBad Aurgment Passed To SetLayer - ") (prin1 name) (exit))) (command "_.LAYER") (if (not (tblsearch "LAYER" name)) (command "_Make" name) (progn (setq ldef (tblsearch "LAYER" name) flag (cdr (assoc 70 ldef))) (and (= (logand flag 1) 1) (command "_Thaw" name)) (and (minusp (cdr (assoc 62 ldef))) (command "_On" name)) (and (= (logand flag 4) 4) (command "_Unlock" name)) (and (= (logand flag 16) 16) (princ "\nCannot Set To XRef Dependent Layer") (quit)) (command "_Set" name))) (command "") name) -David Quote
BlackBox Posted February 24, 2011 Posted February 24, 2011 Building on David's example... this uses ActiveX: (defun SetLayer2 (layerName / activeDoc layerTable layerItem) (vl-load-com) (vla-startundomark (setq activeDoc (vla-get-activedocument (vlax-get-acad-object)))) (if (= 'STR (type layerName)) (if (not (vl-string-search "|" layerName)) (progn (setq layerTable (vla-get-layers activeDoc)) (if (tblsearch "layer" layerName) (progn (setq layerItem (vla-item layerTable layerName)) (vla-put-freeze layerItem :vlax-false)) (vla-put-layeron layerItem :vlax-true) (vla-put-lock layerItem :vlax-false) (setq layerItem (vla-add layerTable layerName))) (vla-put-activelayer activeDoc layerItem)) (prompt "\n <!> Cannot Set to Xref Dependent Layer <!> ")) (progn (prompt "\n <!> Invalid Argument - ") (prin1 name) (prompt " <!> "))) (vla-endundomark activeDoc) (princ)) Quote
alanjt Posted February 24, 2011 Posted February 24, 2011 http://www.theswamp.org/index.php?topic=33041.msg384939#msg384939 Quote
ccowgill Posted February 24, 2011 Posted February 24, 2011 or http://forums.augi.com/showthread.php?t=122277&highlight=layerlist and http://www.theswamp.org/index.php?topic=35588.0;all Quote
autolisp Posted February 25, 2011 Author Posted February 25, 2011 Dear all thx for help me, i will try & revert back thx Quote
