Dennis Posted February 24, 2011 Posted February 24, 2011 Hello, I am working with Autocad 2011 LT. I made a Dynamic block with several linear parameters. i used the stretch action on these parameters. if I insert this block I can change all linear parameter in the propertieswindow when the block is selected but one. I can stretch it when I click on the arrow and drag. but it can't be changed in de propperties window. does anyone now how to solve this? Quote
Dennis Posted February 25, 2011 Author Posted February 25, 2011 Hy! I have found it my self. the problem is if you put your parameter from for example left to right. and you select the arrow on the left side for the snappoint, then it doesn'd work. you can drag it but cant change it in de properties window. so always put your parameter from start point to the direction you later wont to dtretch to. Quote
