nataca Posted February 26, 2011 Posted February 26, 2011 I have problem: (atoms-family 1) -> list variable, function... How to sort or get Variables (create by Autolisp, and not Autocad)? Thanks. Quote
Tharwat Posted February 26, 2011 Posted February 26, 2011 Is this what you mean ... (setq a 1 b 2 c 3) (atoms-family 1 '("a" "b" "c" "d")) Would return d as NIL ("A" "B" "C" nil) Tharwat Quote
pBe Posted February 26, 2011 Posted February 26, 2011 Try this Atoms by MP or http://www.theswamp.org/index.php?topic=30256.msg358398#msg358398 You may need to sign-up atoms16.zip Quote
nataca Posted February 26, 2011 Author Posted February 26, 2011 (edited) thanks. I tried. But There are some Variables can't set ("READ ONLY") It's my code: (defun C:RSB (/ a b) (setq a (vl-remove-if '(lambda (x) (or (wcmatch x "*-*,*_*,C:,AC*,PI,@@@@@@@@@@@*") (not (member (type (eval (read x))) '(INT REAL LIST STR)))) ) ) (atoms-family 1))) (setq b (mapcar'(lambda (x) (set (read x) nil)) a)) (princ) ) Edited February 26, 2011 by nataca Quote
pBe Posted February 26, 2011 Posted February 26, 2011 are your trying to set floating variables to nil? anyhoo... (defun c:RSB () (mapcar' (lambda (x) (set (setq ss (read x)) nil)) (vl-remove-if '(lambda (X) (or (wcmatch x "*-*,*_*,C:,AC*,PI,@@@@@@@@@@@*") (not (or (eq (type (eval (read x))) 'INT) (eq (type (eval (read x))) 'REAL) (eq (type (eval (read x))) 'LIST) (eq (type (eval (read x))) 'STR) )) ) ) (atoms-family 1))) (princ) ) Quote
