How do i union or subtract meshes. i dont think u can
but mabe there is a way
i know about the plugin with mesh to solids but
i need one that is free and not a trial any suggenstions??
thx
hendo
what do you mean trial? there is an autoLISP that will convert mesh to solid. I have a post about it in this forum. As far as adding/subtracting mesh surfaces, i dont know that there is a way but if there is i would like to know. I have used other software packages that would let you SEW a surface to another.
Autolisp
How does it work
Does it come with autocad
What are commands
And please elaborate on sew
I'm modeling a bmw m3 2008
Trying 2 molt front bumper with fender
those arent one piece on the car ;)
The sew command isnt in Acad, it was another cad software i used and as far as i know there isnt a way to join mesh surfaces unless you create them as a single surface.
http://www.cadtutor.net/forum/showthread.php?t=27054
also if you have single facets you can use the thicken command.
acad 07 and up will convert a surface to solid under the tools menu i think. but this will not work for mesh surfaces.
the autolisp is basically a "code" that is run in autocad. you have to load the lisp(*.lsp document) and then whatever the file name is (say m2s for mesh 2 solid) you type m2s in the command line and run it. its very simple but i had to convert my solids to BREP before i could union them, and it didnt like having over/under hangs
You means like surface welding?I am sure autolisp can do it coz i saw this!
