draik Posted March 17, 2011 Posted March 17, 2011 I need to create layers for new, existing and to be remove objects. For new objects, I will need to create a new layer, adding "_N" to the existing layer names. Same goes for exising "_E" and remove items "_R". This is what I have written. (defun c:newwork () (setq entlist (entget (car (entsel "\nSelect object: ")))) (setvar "clayer" (cdr (assoc 8 entlist))) (setq layername (getvar "clayer")) (if (= layername A-_*_**_*) (command "change" "p" "" "p" "la" newlayername "c" "6" "lt" "bylayer" "")) (setq newlayername (strcat layername "_N")) (command "-layer" "m" newlayername "") (command "change" "p" "" "p" "la" newlayername "c" "6" "lt" "bylayer" "") ) (defun c:existing () (setq abc entlist (entget (car (entsel "\nSelect object: ")))) (setvar "clayer" (cdr (assoc 8 entlist))) (setq layername (getvar "clayer")) (setq newlayername (strcat layername "_E")) (command "-layer" "m" newlayername "") (command "change" abc "" "p" "la" newlayername "c" "4" "lt" "bylayer" "") ) (defun c:remove () (setq entlist (entget (car (entsel "\nSelect object: ")))) (setvar "clayer" (cdr (assoc 8 entlist))) (setq layername (getvar "clayer")) (setq newlayername (strcat layername "_R")) (command "-layer" "m" newlayername "") (command "change" "p" "" "p" "la" newlayername "c" "2" "lt" "dashed" "") ) At first, the code seem to work. Then I realise that if I keep changing my mind on whether the item is going to be existing or remove, it will create a lot of layer names. And the layer names can be A-_bldg1234_E-_N_E_R_E_R_E Then I added the "if" code to the newwork comment. Now the codes do not work anymore. Furthermore, the comment do not seems to get the previous selected objects. Can someone help me? Quote
David Bethel Posted March 17, 2011 Posted March 17, 2011 I think I would lean more towards a single function with a variable action on multiple entities: [b][color=BLACK]([/color][/b]defun c:laysuf [b][color=FUCHSIA]([/color][/b]/ et ss en ed ol oe[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]initget 1 [color=#2f4f4f]"New Existing Remove"[/color][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq et [b][color=NAVY]([/color][/b]getkword [color=#2f4f4f]"\nChange To - New/Existing/Remove: "[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq et [b][color=NAVY]([/color][/b]strcase [b][color=MAROON]([/color][/b]strcat [color=#2f4f4f]"_"[/color] [b][color=GREEN]([/color][/b]substr et 1 1[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss 0[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b] ol [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 8 [b][color=RED]([/color][/b]entget en[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] oe [b][color=GREEN]([/color][/b]if [b][color=BLUE]([/color][/b]> [b][color=RED]([/color][/b]strlen ol[b][color=RED])[/color][/b] 2[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]substr ol [b][color=RED]([/color][/b]- [b][color=PURPLE]([/color][/b]strlen ol[b][color=PURPLE])[/color][/b] 1[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] ol[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]entmod [b][color=GREEN]([/color][/b]subst [b][color=BLUE]([/color][/b]cons 8 [b][color=RED]([/color][/b]if [b][color=PURPLE]([/color][/b]member oe '[b][color=TEAL]([/color][/b][color=#2f4f4f]"_E"[/color] [color=#2f4f4f]"_N"[/color] [color=#2f4f4f]"_R"[/color][b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]strcat [b][color=TEAL]([/color][/b]substr ol 1 [b][color=OLIVE]([/color][/b]- [b][color=GRAY]([/color][/b]strlen ol[b][color=GRAY])[/color][/b] 2[b][color=OLIVE])[/color][/b][b][color=TEAL])[/color][/b] et[b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]strcat ol et[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]assoc 8 ed[b][color=BLUE])[/color][/b] ed[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]ssdel en ss[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Quote
stevesfr Posted March 17, 2011 Posted March 17, 2011 I think I would lean more towards a single function with a variable action on multiple entities: [b][color=black]([/color][/b]defun c:laysuf [b][color=fuchsia]([/color][/b]/ et ss en ed ol oe[b][color=fuchsia])[/color][/b] [b][color=fuchsia]([/color][/b]initget 1 [color=#2f4f4f]"New Existing Remove"[/color][b][color=fuchsia])[/color][/b] [b][color=fuchsia]([/color][/b]setq et [b][color=navy]([/color][/b]getkword [color=#2f4f4f]"\nChange To - New/Existing/Remove: "[/color][b][color=navy])[/color][/b][b][color=fuchsia])[/color][/b] [b][color=fuchsia]([/color][/b]setq et [b][color=navy]([/color][/b]strcase [b][color=maroon]([/color][/b]strcat [color=#2f4f4f]"_"[/color] [b][color=green]([/color][/b]substr et 1 1[b][color=green])[/color][/b][b][color=maroon])[/color][/b][b][color=navy])[/color][/b][b][color=fuchsia])[/color][/b] [b][color=fuchsia]([/color][/b]and [b][color=navy]([/color][/b]setq ss [b][color=maroon]([/color][/b]ssget[b][color=maroon])[/color][/b][b][color=navy])[/color][/b] [b][color=navy]([/color][/b]while [b][color=maroon]([/color][/b]setq en [b][color=green]([/color][/b]ssname ss 0[b][color=green])[/color][/b][b][color=maroon])[/color][/b] [b][color=maroon]([/color][/b]setq ed [b][color=green]([/color][/b]entget en[b][color=green])[/color][/b] ol [b][color=green]([/color][/b]cdr [b][color=blue]([/color][/b]assoc 8 [b][color=red]([/color][/b]entget en[b][color=red])[/color][/b][b][color=blue])[/color][/b][b][color=green])[/color][/b] oe [b][color=green]([/color][/b]if [b][color=blue]([/color][/b]> [b][color=red]([/color][/b]strlen ol[b][color=red])[/color][/b] 2[b][color=blue])[/color][/b] [b][color=blue]([/color][/b]substr ol [b][color=red]([/color][/b]- [b][color=purple]([/color][/b]strlen ol[b][color=purple])[/color][/b] 1[b][color=red])[/color][/b][b][color=blue])[/color][/b] ol[b][color=green])[/color][/b][b][color=maroon])[/color][/b] [b][color=maroon]([/color][/b]entmod [b][color=green]([/color][/b]subst [b][color=blue]([/color][/b]cons 8 [b][color=red]([/color][/b]if [b][color=purple]([/color][/b]member oe '[b][color=teal]([/color][/b][color=#2f4f4f]"_E"[/color] [color=#2f4f4f]"_N"[/color] [color=#2f4f4f]"_R"[/color][b][color=teal])[/color][/b][b][color=purple])[/color][/b] [b][color=purple]([/color][/b]strcat [b][color=teal]([/color][/b]substr ol 1 [b][color=olive]([/color][/b]- [b][color=gray]([/color][/b]strlen ol[b][color=gray])[/color][/b] 2[b][color=olive])[/color][/b][b][color=teal])[/color][/b] et[b][color=purple])[/color][/b] [b][color=purple]([/color][/b]strcat ol et[b][color=purple])[/color][/b][b][color=red])[/color][/b][b][color=blue])[/color][/b] [b][color=blue]([/color][/b]assoc 8 ed[b][color=blue])[/color][/b] ed[b][color=green])[/color][/b][b][color=maroon])[/color][/b] [b][color=maroon]([/color][/b]ssdel en ss[b][color=maroon])[/color][/b][b][color=navy])[/color][/b][b][color=fuchsia])[/color][/b] [b][color=fuchsia]([/color][/b]prin1[b][color=fuchsia])[/color][/b][b][color=black])[/color][/b] -David David: I like it.. on suggestion, would be nice to have the option to retain the color and/or linetype as the original layer ? just my 2 cents, Steve Quote
pBe Posted March 17, 2011 Posted March 17, 2011 (edited) Here's my mediocre attempt (defun c:LyrOpt (/ option objs obj obj_e cntr) (setvar 'Dynmode 1) (defun chk_me (lyr Typ clr) (setq lyr (strcat (vl-string-right-trim "_N_E_R" lyr) typ)) (if (not (tblsearch "[color=blue]LAYER"[/color] lyr)) (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 lyr) (cons 62 clr) (cons 70 0))) ) (setq obj_e lyr) ) (Initget 1 "N E R") (setq option (getkword "\nEnter Option [New/Existing/Remove]:")) (setq objs (ssget) cntr -1) (while (setq obj (ssname objs (setq cntr (1+ cntr)))) (setq obj_e (cdr (assoc 8 (entget obj)))) (chk_me obj_e (strcat "_" option) (cadr (assoc option '(("N" 6)("E" 4)("R" 7))))) (vla-put-layer (vlax-ename->vla-object obj) obj_e) ) ) The colors of the layer was based on the OPs request I like Davids code, I never knew you can create a layer on the fly by using (entmod (subst...)) Thank you for that David Nice Edited March 18, 2011 by pBe Ooops "BLOCK" to "LAYER" Quote
David Bethel Posted March 17, 2011 Posted March 17, 2011 David: I like it.. on suggestion, would be nice to have the option to retain the color and/or linetype as the original layer ?just my 2 cents, Steve Maybe like this: [b][color=BLACK]([/color][/b]defun c:laysuf [b][color=FUCHSIA]([/color][/b]/ et ss en ed ol oe nl ul td[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]initget 1 [color=#2f4f4f]"New Existing Remove"[/color][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq et [b][color=NAVY]([/color][/b]getkword [color=#2f4f4f]"\nChange To - New/Existing/Remove: "[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq et [b][color=NAVY]([/color][/b]strcase [b][color=MAROON]([/color][/b]strcat [color=#2f4f4f]"_"[/color] [b][color=GREEN]([/color][/b]substr et 1 1[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss 0[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b] ol [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 8 [b][color=RED]([/color][/b]entget en[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] td [b][color=GREEN]([/color][/b]tblsearch [color=#2f4f4f]"LAYER"[/color] ol[b][color=GREEN])[/color][/b] oe [b][color=GREEN]([/color][/b]if [b][color=BLUE]([/color][/b]> [b][color=RED]([/color][/b]strlen ol[b][color=RED])[/color][/b] 2[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]substr ol [b][color=RED]([/color][/b]- [b][color=PURPLE]([/color][/b]strlen ol[b][color=PURPLE])[/color][/b] 1[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] ol[b][color=GREEN])[/color][/b] nl [b][color=GREEN]([/color][/b]if [b][color=BLUE]([/color][/b]member oe '[b][color=RED]([/color][/b][color=#2f4f4f]"_E"[/color] [color=#2f4f4f]"_N"[/color] [color=#2f4f4f]"_R"[/color][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]strcat [b][color=RED]([/color][/b]substr ol 1 [b][color=PURPLE]([/color][/b]- [b][color=TEAL]([/color][/b]strlen ol[b][color=TEAL])[/color][/b] 2[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] et[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]strcat ol et[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] ul [b][color=GREEN]([/color][/b]if [b][color=BLUE]([/color][/b]tblsearch [color=#2f4f4f]"LAYER"[/color] nl[b][color=BLUE])[/color][/b] nil T[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]entmod [b][color=GREEN]([/color][/b]subst [b][color=BLUE]([/color][/b]cons 8 nl[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]assoc 8 ed[b][color=BLUE])[/color][/b] ed[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]if ul [b][color=GREEN]([/color][/b]command [color=#2f4f4f]"_.LAYER"[/color] [color=#2f4f4f]"_Color"[/color] [b][color=BLUE]([/color][/b]abs [b][color=RED]([/color][/b]cdr [b][color=PURPLE]([/color][/b]assoc 62 td[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] nl [color=#2f4f4f]"_LType"[/color] [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 6 td[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] nl [color=#2f4f4f]""[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]ssdel en ss[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Quote
pBe Posted March 18, 2011 Posted March 18, 2011 .... would be nice to have the option to retain the color and/or linetype as the original layer ?just my 2 cents, Steve in that case: (defun c:LyrOpt (/ option objs obj obj_e cntr [color=blue]pc[/color]) (setvar 'Dynmode 1) (defun chk_me (lyr Typ clr ltyp) (setq lyr (strcat (vl-string-right-trim "_N_E_R" lyr) typ)) (if (not (tblsearch "LAYER" lyr)) (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 lyr) Clr [color=blue]ltyp[/color] (cons 70 0))) ) (setq obj_e lyr) ) (Initget 1 "N E R") (setq option (getkword "\nEnter Option [New/Existing/Remove]:")) (setq objs (ssget) cntr -1) (while (setq obj (ssname objs (setq cntr (1+ cntr)))) (setq obj_e (cdr (assoc 8 (entget obj))) [color=blue] pc (tblsearch "LAYER" obj_e))[/color] (chk_me obj_e (strcat "_" option)[color=blue] (assoc 62 pc)(assoc 6 pc))[/color] (vla-put-layer (vlax-ename->vla-object obj) obj_e) ) ) Quote
David Bethel Posted March 18, 2011 Posted March 18, 2011 Perfect, thank you David: Steve Thanks David, you are a life saver. You're both welcome. I would have thought Demo in lieu of Remove but the overall concept of the makes a lot of sense. 1 gotcha here would be if you pick a old heavy polyline. You are modifying the header but not stepping through all of the sequential entities. Probably not a biggie. Have fun! -David Quote
