vwalla Posted March 17, 2011 Posted March 17, 2011 For some reason, I cannot dimension in paper space. i beleive I have set everything up correctly, but the dimensions in paper space are not correct. See attachement. The circle is 12" in diameter, but if the viewport is 1:2 scale, the diminsion in paper space shows 6". what do i need to do to correct this? Thanks! PaperSpaceDims.zip Quote
vwalla Posted March 17, 2011 Author Posted March 17, 2011 Found the solution: http://www.cadtutor.net/forum/showthread.php?44891-Dimension-Scaling-Problems&highlight=paper+space+dimensions Tools > Options > User Preferences > Check the box "Make new dimensions associative" Quote
