shoyur Posted March 18, 2011 Posted March 18, 2011 Hi, here is my problem : Each month or so, i close a project and start a new one, it is around 25 drawings, containing 5 to 35 pages per drawings, each pages are blocks inside the Model, each blocks contains tags that i need to change, people wants those tags to stay dynamic so i need to edit them 6 tags (date, project name #1, machine model number, project name #2, verified by, revision) in all the blocks, sometimes theres around (25 x ~15 x 6) 2250 tags to change by hand !!!... and cant be used with find replace.. Is there a macro or whatever that i can add as a button to pop textboxes or something to auto change these tags in all instances of the block. I currently have a macro button who puts all layouts PSLTSCALE to 0, so my linetype stay same when i run sheetsets, this is very cool and save my time. It could be multiple buttons/commands. Many Thanks. Quote
JohnM Posted March 18, 2011 Posted March 18, 2011 If they are blocks you can use the gatte command to globally change all similar blocks in a drawing. I believe the gatte command is an express tool Quote
