Macro. Selecting objects with the pause "\"
Hello there.
I was looking for a macro, that locks all layers except the one, that contains the object, that I select.
^C^C-layer;LO;*;U;;\;
Somehow the pause "\" skips object selection. Any suggestions why?
I've not tried it but your macro seems to be missing something, the following would seem more logical:
^C^C-LAYER;LO;;ALL;;U;;\;;
When selecting the layers to freeze you can't use an asterisk (*)
Hope that helps
1. use ai_molc or laymcur to select an object on the layer you want to keep unlocked (also setting it as current).
2. use -layer to lock all layers, then unlock by name, using Diesel to get the current layer $(getvar,clayer)
I'm a coder, not a macro writer, so I'll leave the logistics to someone else.
Maybe...
^C^C_ai_molc;\-layer;LO;*;U;$(getvar,clayer);;
Edited by alanjt
Is _LAYISO available in 2007LT?
I'm pretty sure it became core in 2008. Prior to that it was just a Bonus/Express Tool LISP routine that turn the layers off.
I know it was core in 2008, just wasn't sure about 2007.
