Profile Grid View Problem
One of the guys in our office is having an issue where his edit profile geometry window won't display his 'Profile Grid View' so that he can edit K values manually. He clicks on the 'Profile Grid View' button but no window appears.
The window shows up on other computers in the office, so i'm imagining there's some value for it that is causing it not display. Anyone ever run into this issue or have any idea why this window wouldn't show up on his computer? thanks.
could it be opening off his screen? when the window is suppose to be open, hit Alt+Space+M and then use the arrow keys to move the window.
And check that the variable FILEDIA is set to 1
Is he trying to access it by right-clicking or through the toolspace?
right clicking on the vertical profile alignment, 'edit profile geometry' then click on the 'Profile Grid View'
filedia is already set to 1.
Go to Toolspace and change the setting there. It should work that way.
  • 13 years later...
Hi Burtzlaff, did you solve you problem? because I have the same issue.
