Adding attributes to a block without exploding it.
AutoCAD 2010.
Is it possable to add attributes to a block without exploding it? I have about 10 attributes I would like to
add to some blocks but I don't want to explode the block to add them.
Thank you,
use the block editor, you should be able to select the block, edit it, then add the attributes. when you get done, run attsync on the block and you should be good to go.
