Riddlez Posted September 29, 2008 Posted September 29, 2008 I have been working with VBA for about 2 weeks now and have hit a road block in writing a program. I do have some programming background, but not much and I am probably using funcitons and code snip-its that go well beyond my total understanding of VBA and AutoCAD. Essentially, my code needs to store information from a specified block on all layouts. Then, delete the blocks via their handles. Then purge the old block so that a replacement can be entered from a directory. Then, update the inserted blocks with the old data. Problem 1: I can't seem to get the variable "Entity" to initialize/be assigned an entity/oject/block via the 2nd 'For Each loop' so that I can extract the data. Problem 2: Is there a way to insert my block without using the purgeall command? I've tried to understand a "copy and replace" method, but couldn't wrap my head around it. Problem 3: Is there a way to insert a block and have it simultaneously be assigned to a variable (that would make it so I could modfy the marked areas "Problem 3" so that they can upload attributes via taking the handle off of the inserted block). Any other comments about the code that can save computing time, would help too. And there are some redundant/empty/useless variables, I just haven't been able to weed them out as of yet. Thank you in advance for your help, Riddlez. Option Explicit Sub open_AutoCAD_and_other_files() Dim a, array1, As Variant Dim insrtionpoint(0 To 2) As Double Dim count As Variant Dim vesselname, udblk, blockname, hndle, repblkdir As String Dim vesrow,vesnum, repnum, attnum, atttot, blknum, counter, strt As integer Dim blocknameloc, tagflag, i, j, blknew As Integer Dim x As Variant Dim y As Variant Dim z As Variant Dim excelvsheet, acadapp, excel, acaddoc, currentspace As Object Dim actvecell, actvecells, blk2bdltd As Object Dim Entity As AcadEntity Dim aLAYOUT As AcadLayout Dim cLAYOUT As AcadLayout Dim rttion As Double On Error Resume Next 'Checks if autocad is open and then opens if otherwise Set acadapp = Nothing Set acadapp = GetObject(, "AutoCAD.Application") If Err Then Err.Clear MsgBox ("Autocad is not running, now attempting to hack your e-mail.") Set acadapp = CreateObject("AutoCADLT.Application") Set acadapp = GetObject(, "AutoCAD.Application") acadapp.Visible = 1 End If acadapp.ActiveDocument.Close 'makes autocad visible so that the user can see the files opening acadapp.Visible = 1 'designates the object excel as the application that is open Set excel = GetObject(, "Excel.Application") 'Turns screen updating off so the fuction can run more quickly. Application.ScreenUpdating = False 'Deletes all other worksheets if ok is pressed If MsgBox("Delete uneeded sheets?", vbOKCancel) = vbOK Then Dim ws As Worksheet Application.DisplayAlerts = False For Each ws In ThisWorkbook.Worksheets If ws.Name <> "Sheet1" Then ws.Delete Next ws Application.DisplayAlerts = True Else Exit Sub End If 'moves to sheet1 and counts from A2 to the end of a continuous block of rows to know total number of repetitions Worksheets("Sheet1").Activate vesnum = Range("A2").CurrentRegion.Rows.count 'determines the number of replacement blocks repnum = Range("D2").CurrentRegion.Rows.count 'allows the user to input a value for block that is to be replaced udblk = InputBox("What block do you wish to replace?", "User Input", "NULL") 'Begins the "big" loop - Contains the functions that will be repeated for each file For vesrow = 2 To (vesnum + 1) 'the ending value is not inclusive (i.e. 1 To 4 does 3 iterations, 1,2 and 3) 'looks in Sheet1 for the vessel name, checks if there is a sheet by that name and creates it if there isn't one Worksheets("Sheet1").Activate vesselname = Cells(vesrow, 1) Worksheets(vesselname).Activate If Err Then Error.Clear Sheets.Add.Name = "" & vesselname End If 'open autocad doc from cell Worksheets("Sheet1").Activate Set acaddoc = acadapp.Documents.Open(Cells(vesrow, 2)) 'initializes blknum to 0, since this is the beginning of a new dwg blknum = 0 tagflag = 1 'PROBLEM 1 For Each aLAYOUT In acaddoc.Layouts ActiveWorkbook.Sheets(vesselname).Cells(blknum + 1, 1).EntireRow.Borders.Item(xlEdgeBottom).Weight = xlThick aLAYOUT.Activate If aLAYOUT.Name <> "Model" Then 'starts a loop that checks ALL objects/elements in a space For Each Entity In aLAYOUT.Block With Entity 'If the block is the one that is going to be replaced, then place a 1 in the 200th row of the block's column, otherwise put a 0 If Entity.Name = udblk Then 'Increment the block count by one since it has found a new block blknum = blknum + 1 'not sure if 'a' is necessary, but this part gets the attributes and insertion points of the current block a = .GetDynamicBlockProperties Application.StatusBar = "Processing: " & CStr(Entity.Handle) array1 = .GetAttributes array2 = .insertionpoint 'check total number of attributes in array1 and add one because Ubound returns the last array number which is one less than the total amount of points attnum = UBound(array1) + 1 'store the total number of attributes for use in placing the information into columns atttot = attnum If tagflag = 1 Then counter = attnum While counter > 0 ActiveWorkbook.Sheets(vesselname).Cells(1, atttot - counter + 1).Value = array1(atttot - counter).TagString counter = counter - 1 Wend ActiveWorkbook.Sheets(vesselname).Cells(1, 252).Value = "x" ActiveWorkbook.Sheets(vesselname).Cells(1, 253).Value = "y" ActiveWorkbook.Sheets(vesselname).Cells(1, 254).Value = "z" ActiveWorkbook.Sheets(vesselname).Cells(1, 255).Value = "Element Rotation" ActiveWorkbook.Sheets(vesselname).Cells(1, 256).Value = "Element Handle" tagflag = tagflag - 1 End If 'for every attribute, place the stored information in a column While attnum > 0 ActiveWorkbook.Sheets(vesselname).Cells(blknum + 1, atttot - attnum + 1).Value = array1(atttot - attnum).TextString attnum = attnum - 1 Wend 'after the attributes listed in the column, place the handle, insertion point and name of the attribute x = array2(0) y = array2(1) z = array2(2) ActiveWorkbook.Sheets(vesselname).Cells(blknum + 1, 252).Value = x ActiveWorkbook.Sheets(vesselname).Cells(blknum + 1, 253).Value = y ActiveWorkbook.Sheets(vesselname).Cells(blknum + 1, 254).Value = z ActiveWorkbook.Sheets(vesselname).Cells(blknum + 1, 255).Value = .Rotation ActiveWorkbook.Sheets(vesselname).Cells(blknum + 1, 256).Value = "'" & CStr(Entity.Handle) 'end If End If End With Next Entity End If Next aLAYOUT 'limit the next loop to the number of blocks in existance counter = blknum strt = 2 'conditionally searches row 200 for a 1. if it finds it, it 'replaces the block with a block from another file and uploads the data While counter > 0 ActiveWorkbook.Sheets(vesselname).Activate hndle = Cells(strt, 256).Value Set blk2bdltd = acadapp.ActiveDocument.HandleToObject(hndle) blk2bdltd.Delete counter = counter - 1 strt = strt + 1 Wend 'PROBLEM 2 -is there a way to do this without deleting unused Layers? acaddoc.PurgeAll counter = blknum strt = 2 While counter > 0 ActiveWorkbook.Sheets(vesselname).Activate insrtionpoint(0) = Cells(strt, 252).Value insrtionpoint(1) = Cells(strt, 253).Value insrtionpoint(2) = Cells(strt, 254).Value rttion = Cells(strt, 255).Value 'could be paper space depending on function. for testing it is the model space repblkdir = excel.ActiveWorkbook.Sheets("Sheet1").Cells(2, 5).Value 'PROBLEM 3 elem2 = acaddoc.ModelSpace.InsertBlock(insrtionpoint, repblkdir, 1#, 1#, 1#, rttion) counter = counter - 1 strt = strt + 1 Wend Set currentspace = acaddoc.ModelSpace 'PROBLEM 3 blknew = 0 count = acaddoc.ModelSpace.count While blknum > 0 Set elem2 = acaddoc.ModelSpace.Item(count - blknum) 'Checks to see if the element is a block If StrComp(elem2.EntityName, "AcDbBlockReference", 1) = 0 Then 'If the block is the one that is going to be replaced, then place a 1 in the 200th row of the block's column, otherwise put a 0 If elem2.Name = udblk Then blknew = blknew + 1 'not sure if 'a' is necessary, but this part gets the attributes and insertion points of the current block a = elem2.GetDynamicBlockProperties Application.StatusBar = "Processing: " & CStr(elem2.Handle) array1 = elem2.GetAttributes array2 = elem2.insertionpoint For i = 0 To atttot - 1 array1(i).TextString = ActiveWorkbook.Sheets(vesselname).Cells(blknew + 1, i + 1) Next i ActiveWorkbook.Sheets(vesselname).Cells(blknew + 1, 256).Value = "'" & CStr(elem2.Handle) strt = strt + 1 End If End If blknum = blknum - 1 Wend acaddoc.Save acaddoc.Close Next vesrow 'Incase of error, still shows AutoCAD acaddoc.Visible = 1 End Sub Quote
Riddlez Posted September 29, 2008 Author Posted September 29, 2008 I forgot to mention that it is using excel as the interface, in that all the directories and sheet names would have to be inserted into "Sheet1" in Row 2 and down. Column 1 for the reference/file/vessel name and Column 2 for the directory of the file with the aforementioned name. Columns 4 and 5 are for the block that is going to be replaced throughout all the files. This is so that you can dump names and directories into the spreadsheet and have the code do it's thing for all the files. I'm sorry ahead of time, if I am doing anything that is considered: inconsiderate, of bad manners when posting in a forum or anything of such a nature. I look forward to you responses, Riddlez. Quote
Riddlez Posted September 30, 2008 Author Posted September 30, 2008 Solved my problem. Sorry to anyone that has been trying to work it out before they responded. If anyone wants to know what I did, feel free to drop a reply asking. Cheers, Riddlez. Quote
