eturner Posted March 31, 2011 Share Posted March 31, 2011 Is there a way for a new line I'm drawing to automatically match properties to the line I've snapped to? Often times the item holding me back from working quicker is changing the layers around quickly. Not sure if this is a company lisp command or ACAD, but I do use "SL" to set the layer, which is relatively quick, but it would be much nicer if autocad would just know that if I'm snapping to something, 99% of the time I want the new line to be the same layer... is that an option anywhere? thanks!! Erik Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 1, 2011 Share Posted April 1, 2011 Theres a program that allows you pick an object and make a new object with the same characteristics layer color etc I downloaded it from here but can not remember what it was called so I have pasted it here ; matches pick object for next command plus layer (defun c:ZZZ (/ ent Obj lEnt) (vl-load-com) (while (setq ent (car (nentsel "\nSelect Object: "))) (setq Obj (vlax-ename->vla-object ent) typ (cdr (assoc 0 (entget ent)))) (cond ((vl-position typ '("CIRCLE" "ARC" "ELLIPSE" "SPLINE" "XLINE")) (comInv typ nil) (PropMatch Obj (entlast))) ((eq "LWPOLYLINE" typ) (comInv "pline" nil) (PropMatch Obj (entlast))) ((eq "LINE" typ) (setq lEnt (entlast)) (comInv typ nil) (foreach ent (EntCol (if lEnt lEnt (entlast))) (PropMatch Obj ent))) ((eq "HATCH" typ) (setq lEnt (entlast)) (comInv typ t) (if (not (eq lEnt (entlast))) (PropMatch Obj (entlast)))) ((eq "VIEWPORT" typ) (setq lEnt (entlast)) (comInv "-vports" nil) (if (not (eq lEnt (entlast))) (PropMatch Obj (entlast)))))) (princ)) (defun PropMatch (bObj dObj) (or (eq 'VLA-OBJECT (type bObj)) (setq bObj (vlax-ename->vla-object bObj))) (or (eq 'VLA-OBJECT (type dObj)) (setq dObj (vlax-ename->vla-object dObj))) (foreach prop '(Layer Linetype LinetypeScale Color Lineweight ViewportOn ShadePlot DisplayLocked GradientAngle GradientCentered GradientColor1 GradientColor2 GradientName HatchObjectType HatchStyle ISOPenWidth Origin PatternAngle PatternDouble PatternScale PatternSpace) (if (and (vlax-property-available-p bObj prop) (vlax-property-available-p dObj prop T)) (vlax-put-property dObj prop (vlax-get-property bObj prop))))) (defun EntCol (x / x) (if (setq x (entnext x)) (cons x (EntCol x)))) (defun comInv (com flag) (if flag (initdia)) (command (strcat "_." com)) (while (eq 1 (logand 1 (getvar "CMDACTIVE"))) (command pause))) Quote Link to comment Share on other sites More sharing options...
