rodrigo_gcmsoft Posted April 5, 2011 Posted April 5, 2011 I have a routine in C # that lists all the vertices of a polyline. I wonder how the distance between each vertex and what angle to the y-axis of the drawing. Anyone have any ideas? CODE: [CommandMethod("listaVertices")] static public void ListVertices() { Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument; Editor ed = doc.Editor; Database db = doc.Database; PromptEntityResult per = ed.GetEntity("Select a polyline"); if (per.Status == PromptStatus.OK) { Transaction tr = db.TransactionManager.StartTransaction(); using (tr) { DBObject obj = tr.GetObject(per.ObjectId, OpenMode.ForRead); // If a "lightweight" (or optimized) polyline Polyline lwp = obj as Polyline; if (lwp != null) { // Use a for loop to get each vertex, one by one int vn = lwp.NumberOfVertices; for (int i = 0; i < vn; i++) { // Could also get the 3D point here Point2d pt = lwp.GetPoint2dAt(i); ed.WriteMessage("\n" + pt.ToString()); } } else { // If an old-style, 2D polyline Polyline2d p2d = obj as Polyline2d; if (p2d != null) { // Use foreach to get each contained vertex foreach (ObjectId vId in p2d) { Vertex2d v2d = (Vertex2d)tr.GetObject(vId, OpenMode.ForRead); ed.WriteMessage("\n" + v2d.Position.ToString()); } } else { // If an old-style, 3D polyline Polyline3d p3d = obj as Polyline3d; if (p3d != null) { // Use foreach to get each contained vertex foreach (ObjectId vId in p3d) { PolylineVertex3d v3d = (PolylineVertex3d)tr.GetObject(vId, OpenMode.ForRead); ed.WriteMessage("\n" + v3d.Position.ToString()); } } } } // Committing is cheaper than aborting tr.Commit(); } } } Thanks! Rodrigo Quote
