ses4 Posted April 11, 2011 Posted April 11, 2011 Please edit this as I want, not lisp blocks Could you put here? http://rapidshare.com/files/456875969/kam__iz.xls http://rapidshare.com/files/456862686/PointList.dvb KAMÇİZ.dwg Function; - Before you ask us to pick the circle - Then spline object (cam cross-section) to be selected - we chose the center of the circle as the origin of the coordinate system to take - y axis of the spline to be cut off since the peak - Clockwise (clockwise) for every 1 degree of scrolling through an imaginary line - Locate the point of intersection with this line, spline - x and y coordinates with point number to write to the file Quote
