cggentry Posted April 11, 2011 Share Posted April 11, 2011 This seems like something that should be easy, but I'm not able to get it to work. I've been working on some macros with the action recorder, and I need to place them onto a tool palette. I'm having a hard time figuring out how to do this. Thanks for your help! Quote Link to comment Share on other sites More sharing options...
edwinprakoso Posted April 13, 2011 Share Posted April 13, 2011 (edited) You need to create a custom command in CUI first. Assign the command to run your recorded action. Then drag the command to tool palette. Or place any object in tool palette (line, arc, doesn't matter) then edit the command string. See here for more details. Edited April 13, 2011 by edwinprakoso adding information Quote Link to comment Share on other sites More sharing options...
cggentry Posted April 13, 2011 Author Share Posted April 13, 2011 Brilliant. Thank you! Quote Link to comment Share on other sites More sharing options...
