I found this code on the net and can't figure out what's wrong.
I need to find the last angle so I can insert a block to the last point in the direction of the last angle. Any help is much appreciated.
(DEFUN C:FPOLE(/ ent sub1 ptlist pt1 pt2 ang)
(COMMAND "pLINE")
(while (= 1 (getvar "cmdactive"))
(command pause)
(SETQ ENT (CAR (ENTLAST)))
(SETQ SUB1 (ENTNEXT ENT))
(SETQ PTLIST NIL)
(WHILE SUB1
(IF (= (CDR (aSSOC 0 (ENTGET SUB1))) "VERTEX")
(SETQ PTLIST (APPEND PTLIST (LIST
(CDR (aSSOC 10 (ENTGET SUB1))))))
(SETQ SUB1 (ENTNEXT SUB1))
(SETQ PT1 (CADR (REVERSE PTLIST)))
(SETQ PT2 (LAST PTLIST))
(SETQ ANG1 (ANGLE PT1 PT2))
(SETQ ANG2 (RTOS (* 180.0 (/ ANG1 pi))) 2 4)
(COMAND "INSERT" "FLAG" "1" "1" ANG2)
The last 'command' function has only one 'm', and the Insert command doesn't specify an Insertion Point.
I would be inclined however to use the curve functions for this task, since the code will then be suitable for Arcs, Circles, Lines, Polylines, LWPolylines, Ellipses, Splines etc.
(defun c:test ( / a e p ) (vl-load-com)
 (if
   (and (setq e (car (entsel)))
     (not
       (vl-catch-all-error-p
         (setq p
           (vl-catch-all-apply 'vlax-curve-getEndParam (list e))
     (setq a (* 180. (/ (angle '(0. 0. 0.) (vlax-curve-getFirstDeriv e p)) pi)))
   (command "_.-insert" "flag" "_non" (trans (vlax-curve-getPointatParam e p) 0 1) "1" "1" a)
Note that there is no checking for existence of the 'flag' block.
Thanks Lee! your the best. You always inspires me on how simple to do lisp yet too complicated on one simple mind. :)
Thanks Shakuhachi :)
I'm glad I could provide some inspiration with my posts :)
